Buy EcoFlow RIVER mini Portable Power Station | RIVER mini (Wireless)
EcoFlow RIVER Mini Portable Power Station EcoFlow RIVER Mini Portable Power Station
Regular price USD $399.00
Sale price USD $399.00 Regular price $399.00
-$0
We have suspended the production and sales of this product. Thank you for your interest. We recommend checking out our latest products from the RIVER series.
• 210Wh of Power at Hand
• Includes a variety of ports to power up to 8 devices at once
• 1.5 hours X-Stream fast charging
• Lightweight and portable: 6.3lbs, easy to carry
• 100W solar input, recharge in 2 hrs
• App control
Fast Charging
Multiple Ports
Power Multiple Devices
Lightweight & Portable
Take wall outlets anywhere.
Power the big stuff with the RIVER mini’s AC wall outlets. With a 300W output (600W surge), RIVER mini is ideal for 99% of your devices. Laptops, lights, TVs. It’s all good.
Charging is a chore, so we made it faster.
RIVER mini charges to 80% in 1 hour flat. That's way faster than your powerbank, all in a battery that has about 6 times the capacity. Not near a wall? Charge with solar or via your car for when you’re on-the-go.
All the ports.
RIVER mini has all the ports & outlets you’d ever need. 2 AC wall outlets, 1 DC car outlet, 3 USB-A ports and a USB-C fast-charge port. It even has a wireless charging pad up top. With all that, you can power up to 8 devices at once.
It fits in your hand too.
All that in a power station that fits in your hand. Grab RIVER mini, throw it in your backpack and you’re good to go.
Safety first.
Not only is the RIVER mini made to last with a tough, one-piece build. It sports an advanced BMS for voltage, current, and temperature protection too.
AC Charging
Charge from AC wall outlets in 1.5 hour.
Car Charging
Charge from your car outlet in 3.5 hours.
Charge from 100W of solar panels in 3—6 hours.
RIVER mini Wireless Product Box
1. RIVER mini Wireless 2. AC Charging Cable 3. Car Charging Cable 4. Quick Start Guide and Warranty Card
RIVER mini has a 210Wh capacity. That’s roughly 58400mAh. In other words, it's much larger than a powerbank, and much more portable than most power stations. The goldilocks zone.
RIVER mini is 6.3 lbs (2.85kg), light enough to throw in your backpack and take anywhere.
RIVER mini has a 300W output (600W surge); that means it can power 99% of your devices such as phones, laptops, lights, and fans. However, you can check what wattage your device uses to confirm compatibility.
RIVER mini supports solar charging, ideal for camping and the outdoors. It supports up to 100W of solar input charging to full in 3–6 hours. Just make sure your solar panel hits these specs: 11–39V, 8A, up to 100W.
210Wh (25.2V)
Approximately 6.3lbs
9.8 x 5.5 x 5.2inches
AC Input
100-120V~ 50Hz/60Hz, 6.0A Max
DC Input
11-39V 100W, 8A Max
DC Output
12.6V 10A
USB-C Output (Only for RIVER mini Wireless)
100W, 5A MAX
5V 2.4A
Pure Sine Wave, 300W total (surge 600W), 120V~ 60Hz
Wireless Output (Only for RIVER mini Wireless)
15W Max
Cell Chemistry
NCM
80%+ capacity after 500 cycles
Discharge Temperature
-20°C to 45°C
Charge Temperature
0°C to 45°C
Optimal Operating Temperature
20°C to 30°C
Storage Temperature
-20°C to 45°C
*USB-C fast-charge port and wireless charging pad are exclusive to the wireless version of RIVER mini.
Thanks for sharing!
