Buy EcoFlow DELTA Portable Power Station | DELTA (1300)
EcoFlow DELTA Portable Power Station EcoFlow DELTA Portable Power Station
USD $899.00
Regular price USD $899.00
Sale price USD $899.00 Regular price $1,399.00
-$500
• The new standard of battery-powered generators
• Charge from 0%-80% within 1 hour
• 6x AC Outlets (Total 1800W) & 1260Wh capacity
• Fast charge via solar and car
• Power 13 devices simultaneously
A smarter evolution of DELTA
DELTA 3 Plus — Faster Charging. Longer Lifespan.
•1-5kWh expandable with DELTA 3 Extra Battery, DELTA Pro 3 Extra Battery, DELTA 2 Extra Battery or DELTA 2 Max Extra Battery.
•1800W AC output, 2200W (surge 3600W) with X-Boost
•5 fast recharging methods (AC, Solar, 800W Alternator Charger, Smart Generator 3000 (Dual Fuel), Multicharging)
•5-year warranty
Model
EcoFlow App control not supported
USD $899 $1,399 -$500
Stay in charge of any situation with DELTA and keep your devices powered at all times. DELTA has a huge 1260Wh capacity that’s perfect for power outages, outdoor adventures, and professional work.
High Capacity
X-Stream Fast Charge
6x AC Outlets
Power Multiple Devices
Never lose power again
DELTA has a huge 1260Wh capacity that keeps your home devices fully charged during power outages and emergencies.
The world’s fastest charging portable power stations
EcoFlow have the world's fastest charging power stations. DELTA charges from 0-80% in under an hour, giving you a quick boost of power even during the worst situations.
Power your essential devices
With 6x 1800W AC outlets, DELTA lets you power essential devices when you’re at home and heavy-duty power tools when you’re working outdoors.
One device to rule them all
DELTA can power up to 13 devices at the same time. That’s enough juice for brewing a cup of coffee, listening to your favourite radio station, or journeying into Middle-earth again.
You're in Charge
Solar charging
Harness the power of the sun by connecting DELTA to three 160W solar panels to fully charge in just 3.5-7 hours. Alternatively, you can connect DELTA to four 110W solar panels to fully charge in 4-8 hours.
Car charging
Heading on a long road trip? DELTA can be charged in 13.5 hours using a car adaptor.
Wall outlet
Plug DELTA into any standard AC wall outlet to fast charge from 0-80% in under 1 hour and get fully charged in just 96 minutes.
Compare The Models
DELTA
Capacity:1260Wh
Life Cycles: 800+ Cycle
Output: 1800W (Surge 3300W)
AC Input: 1200W Max
Solar Input: 400W
$1399
RIVER Pro
Capacity:720Wh
Output: 600W (Surge 1200W)
AC Input: 660W Max
Solar Input: 200W
$649
RIVER Max
Capacity:576Wh
Life Cycles: 500+ Cycle
AC Input: 500W Max
Solar Input: 200W
$599
DELTA can be recharged to 0%~80% in 1 hour, and be fully recharged within 1.6 hours.
Under perfect sunlight conditions, DELTA can be fully charged with the following solar panel setups: 1x 110W solar panel: 16h-32h 2x 110W solar panel (in series): 7.5h-15h 3x 110W solar panel (in series): 5h-10h 4x 110W solar panel: 4-8hrs
Yes. During this situation, DELTA will prioritise AC charging, and default to DC charging when AC charging is not used.
It can be an emergency power source (EPS), which will have the same result as UPS for most electronics. Here's the difference. When your DELTA is plugged into the wall, anything plugged into it gets power from the grid, not its battery. If power from the grid stops, DELTA automatically switches to its battery supply mode within 30 milliseconds. That means anything connected will not have power for 30 milliseconds, which may mean sensitive electronics like desktop computers and data servers turn off. Test your devices individually to see if they need UPS to stay powered.
DELTA can power essential devices whether you’re at home or outdoors. Devices include lights, microwave ovens, fridges, hairdryers, laptops, phones, electric frying pans, and more.
Specs of DELTA (1300)
30.9lbs (14kg)
Dimension
15.7 x 8.3 x 10.6 in (40 x 21 x 27 cm)
Charge Temperature
32 to 113°F (0 to 45°C)
Discharge Temperature
-4 to 113°F (-20 to 45°C)
Color
Gray & black
24 months
Charge Method
AC Wall Outlet, 12V Car Adaptor, Solar Panel
Full Recharge Time
1.6 Hours (AC) 13.5 Hours (12/24V Car Adaptor) 4-8 Hours (Using 4x 110W Solar Panels in parallel) 3.5-7 Hours (Using 3x 160W Solar Panels) 4-8 Hours (Using 1x400W Solar Panel)
1260Wh (50.4V)
Cell Chemistry
Lithium-ion
Life Span
800 Cycles to 80%+ capacity
Management Systems
BMS, Over Voltage Protection, Overload Protection, Over Temperature Protection, Short Circuit Protection, Low Temperature Protection, Low Voltage Protection, Overcurrent Protection.
Cell Type
18650
AC Charge Input Power
X-Stream charge (1200W max)
AC Charge Input Voltage
100-120Vac (50Hz/60Hz)
Solar Charge Input
400W 10-65V DC 10A max
Car Charger
12V/24V DC 8A max
AC Output (x6)
1800W total (Surge 3300W), 120Vac (60Hz)
USB-A Output (x2)
5V DC, 2.4A, 12W Max, per port
USB-A Fast Charge (x2)
5V/2.4A,9V/2A,12V/1.5A 18W Max
USB-C Output (x2)
5V DC, 9V DC, 15V DC, 20V DC, 3A, 60W Max, per port
Car Power Output (x1)
108.8W, 13.6V DC, 8A max
Specs of DELTA (1000)
30.9lbs (14kg)
Dimension
Charge Temperature
Color
Gray & black
24 months
Charge Method
Full Recharge Time
1.6 Hours (AC) 10.5 Hours (12/24V Car Adaptor) 2.6-5.3 Hours (Using 3x 160W Solar Panels) 3.2-6.3 Hours (Using 1x 400W Solar Panel)
1008Wh
Cell Chemistry
NCM
Life Span
500 cycles to 80%+ capacity
Management Systems
Cell Type
18650
X-Stream charge (1000W max)
Solar Charge Input
Car Charger
12V/24V DC 8A max
AC Output (x6)
1600W total (Surge 3100W), 120Vac (60Hz)
USB-A Output (x2)
USB-C Output (x2)
Solar charging
Car charging
Wall outlet
30.9lbs (14kg)
Dimension
Charge Temperature
Charge Method
Full Recharge Time
1260Wh (50.4V)
Cell Chemistry
Lithium-ion
Life Span
Management Systems
Cell Type
18650
Solar Charge Input
Car Charger
12V/24V DC 8A max
AC Output (x6)
USB-A Output (x2)
USB-C Output (x2)
30.9lbs (14kg)
Dimension
Charge Temperature
Color
Gray & black
24 months
Charge Method
Full Recharge Time
1008Wh
Cell Chemistry
NCM
Life Span
Management Systems
Cell Type
18650
Solar Charge Input
Car Charger
12V/24V DC 8A max
AC Output (x6)
USB-A Output (x2)
USB-C Output (x2)
