Buy EcoFlow 220W Bifacial Portable Solar Panel
EcoFlow NextGen 220W Bifacial Portable Solar Panel Bundle EcoFlow NextGen 220W Bifacial Portable Solar Panel Bundle EcoFlow NextGen 220W Bifacial Portable Solar Panel Bundle EcoFlow NextGen 220W Bifacial Portable Solar Panel Bundle EcoFlow NextGen 220W Bifacial Portable Solar Panel Bundle
Regular price USD $299.00
Sale price USD $299.00 Regular price $649.00
-$350
Two in one EcoFlow’s 220W Bifacial Portable Solar Panel is two in one. With a 220W primary side, and a 155W side on the back for ambient light, you can capture up to 25% more solar energy and charge your portable power station even faster.
Tempered glass. Built to last The thin, one-piece tempered glass design makes it five times tougher than comparable panels, it can withstand heat up to 300°F too. Safe to say it can withstand the elements.
Compact. Portable It’s a portable solar panel designed from the ground up to be compact. 10% smaller than comparable 220W panels, it saves space with thinner tempered glass, and less surface area required for the same input.
More than a carry case It comes with its own carry case so you can take it anywhere. Once you arrive at your destination, simply unfold it and use it as a kickstand to get your sun exposure just right.
Waterproof We’ve raised the bar with this panel. It's completely water and dust-tight. Rain, wind or shine, your panel is safe with an IP68 waterproof rating.
Accessories
USD $299 $649 -$350
Capture more energy with a dual-sided design
With a 220W primary side, and a 175W side on the back for ambient light, you can capture up to 28% more solar energy and charge your portable power station even faster.
Generate even more energy
With the portable solar panel industry's first use of TOPCon solar technology,
we've raised the bar on conversion efficiency, reaching 25%.
Charge faster with a more compact panel.
Capture more solar with an adjustable angle
With a newly integrated solar angle guide and stand,
adjust the angle of the panel by 30 degrees in seconds to get the most sunshine at all times.
Durable and waterproof
Built to weather the storm
With an IP68 waterproof rating, our NextGen 220W Bifacial Solar Panel maintains its high performance even when it's in contact with water. So you can recharge near a lake or take it out on your boat without worry!
Never too hot
Designed to withstand high temperatures while still ensuring high levels of solar generation.
Lightweight and portable
Generate solar energy anywhere with our compact-designed panels. Fold away to store in your van or closet, pull them out in seconds to start using.
EcoFlow Solar Panel Comparison
NextGen vs.Original
NEW
EcoFlow NextGen Portable Solar Panel
EcoFlow Solar Panel
EcoFlow Solar Panel
Cell Type
N Type TOPCon
monocrystalline silicon
P Type PERC
Conversion Efficiency
Weight
(5.1 kg-7.2 kg)
(5.6 kg-9.5 kg)
Stand Type
30-60° Integrated Adjustable Stand
Separate Kickstand Case
Additional Feature
Integrated Solar Angle Guide
No Solar Angle Guide
What’s in the box
XT60i Charging Cable
Protective Bag
Protective Bag
Quick Start Guide, Safety Instructions & Warranty Card
Rated Power
220W (±5W) Front/175W Rear
Cell Type
N Type TOPCon monocrystalline silicon
Efficiency
25.00%
Weight (Solar Panel)
Approx. 15.4 lb (7.0 kg)
Unfolded: 24.2×84.8×1.0 in/615×2155×25 mm
Folded: 24.2×23.2×1.3 in/615×590×32 mm
Connector Type
Photovoltaic connectors
Warranty (US)
12 months
Open Circuit Voltage
21.5V (Vmp 18.4V)
Short Circuit Current
12.4A (Imp 11.9A) Front Side/ 9.9A (Imp 9.5A) Rear Side
Waterproof & Dustproof
Thanks for sharing!
