EcoFlow DELTA Solar Generator (PV 160W) - DELTA (1300) / 3*160W - EcoFlow
EcoFlow DELTA Solar Generator (PV 160W) EcoFlow DELTA Solar Generator (PV 160W) EcoFlow DELTA Solar Generator (PV 160W) EcoFlow DELTA Solar Generator (PV 160W) EcoFlow DELTA Solar Generator (PV 160W) EcoFlow DELTA Solar Generator (PV 160W)
USD $1,799.00
Regular price USD $1,799.00
Sale price USD $1,799.00 Regular price $2,746.00
-$947
  • Generates up to 2kWh to 2.5kWh daily.
  • 1600W to 1800W AC output.
  • A high conversion rate guarantees a fast solar charging speed: 0-100% in 4-5 hours (2 sets) and 7.5-10 hours (1 set)
  • 160W Solar Panel: IP68 dust and water resistance. It works well in extreme conditions.
  • 2-year warranty for DELTA and 12-month warranty for 160W Portable Solar Panel.
**DELTA and 160W Portable Solar Panel will be shipped separately.
Shipment services to Alaska, Puerto Rico, and Hawaii are temporarily suspended.
Model
EcoFlow App control not supported
Number of Solar Panel
USD $1,799 $2,746 -$947
Stay in charge of any situation with DELTA and keep your devices powered at all times. DELTA has a huge 1260Wh capacity that’s perfect for power outages, outdoor adventures, and professional work.
High Capacity
X-Stream Fast Charge
6x AC Outlets
Power Multiple Devices
The world’s fastest charging portable power stations
EcoFlow have the world's fastest charging power stations. DELTA charges from 0-80% in under an hour, giving you a quick boost of power even during the worst situations.
So Much More Sun
32 premium monocrystalline silicon cells provide a high conversion efficiency of 22%. Recharge even faster by chaining multiple panels in series or in parallel.
Better Together
Recharge freely and naturally when you link EcoFlow’s 110W Solar Panel to a DELTA portable power station.
Compare The Models
DELTA
Capacity:1260Wh
Life Cycles: 800+ Cycle
Output: 1800W (Surge 3300W)
AC Input: 1200W Max
Solar Input: 400W
$1399
RIVER Pro
Capacity:720Wh
Output: 600W (Surge 1200W)
AC Input: 660W Max
Solar Input: 200W
$649
RIVER Max
Capacity:576Wh
Life Cycles: 500+ Cycle
AC Input: 500W Max
Solar Input: 200W
$599
DELTA can be recharged to 0%~80% in 1 hour, and be fully recharged within 1.6 hours.
Under perfect sunlight conditions, DELTA can be fully charged with the following solar panel setups: 1x 110W solar panel: 16h-32h 2x 110W solar panel (in series): 7.5h-15h 3x 110W solar panel (in series): 5h-10h 4x 110W solar panel: 4-8hrs
Yes. During this situation, DELTA will prioritise AC charging, and default to DC charging when AC charging is not used.
It can be an emergency power source (EPS), which will have the same result as UPS for most electronics. Here's the difference. When your DELTA is plugged into the wall, anything plugged into it gets power from the grid, not its battery. If power from the grid stops, DELTA automatically switches to its battery supply mode within 30 milliseconds. That means anything connected will not have power for 30 milliseconds, which may mean sensitive electronics like desktop computers and data servers turn off. Test your devices individually to see if they need UPS to stay powered.
DELTA can power essential devices whether you’re at home or outdoors. Devices include lights, microwave ovens, fridges, hairdyers, laptops, phones, electric frying pans, and more.
Increase the efficiency of your solar panel by facing it directly at the sun without any obstructions. Remember to be careful when handling your solar panel because damaged cells provide less power.
Yes, if the only thing between it and the sun is transparent, but it won’t charge as well compared to being outside. You can compare the difference by looking at the input section of your power station’s LCD screen.
Specs of DELTA (1300)
30.9lbs (14kg)
Dimension
15.7 x 8.3 x 10.6 in (40 x 21 x 27 cm)
Charge Temperature
32 to 113°F (0 to 45°C)
Discharge Temperature
-4 to 113°F (-20 to 45°C)
Color
Gray & black
24 months
Charge Method
AC Wall Outlet, 12V Car Adaptor, Solar Panel
Full Recharge Time
1.6 Hours (AC) 13.5 Hours (12/24V Car Adaptor) 4-8 Hours (Using 4x 110W Solar Panels in parallel) 3.5-7 Hours (Using 3x 160W Solar Panels) 4-8 Hours (Using 1x400W Solar Panel)
1260Wh (50.4V)
Cell Chemistry
Lithium-ion
Shelf Life
1 year (after fully charged)
Life Span
800 Cycles to 80%+ capacity
Management Systems
BMS, Over Voltage Protection, Overload Protection, Over Temperature Protection, Short Circuit Protection, Low Temperature Protection, Low Voltage Protection, Overcurrent Protection.
Testing and certification
UL CE FCC RoHS PSE
Cell Type
18650
AC Charge Input Power
X-Stream charge (1200W max)
AC Charge Input Voltage
100-120Vac (50Hz/60Hz)
Solar Charge Input
400W 10-65V DC 10A max
Car Charger
12V/24V DC 8A max
AC Output (x6)
1800W total (Surge 3300W), 120Vac (60Hz)
USB-A Output (x2)
5V DC, 2.4A, 12W Max, per port
USB-A Fast Charge (x2)
5V/2.4A,9V/2A,12V/1.5A 18W Max
USB-C Output (x2)
5V DC, 9V DC, 15V DC, 20V DC, 3A, 60W Max, per port
Car Power Output (x1)
108.8W, 13.6V DC, 8A max
Specs of DELTA (1000)
30.9lbs (14kg)
Dimension
Charge Temperature
Color
Gray & black
24 months
Charge Method
Full Recharge Time
1.6 Hours (AC) 10.5 Hours (12/24V Car Adaptor) 2.6-5.3 Hours (Using 3x 160W Solar Panels) 3.2-6.3 Hours (Using 1x 400W Solar Panel)
1008Wh
Cell Chemistry
NCM
Shelf Life
Life Span
500 cycles to 80+% capacity
Management Systems
UL CE FCC RoHS PSE
Cell Type
18650
X-Stream charge (1000W max)
Solar Charge Input
Car Charger
12V/24V DC 8A max
AC Output (x6)
1600W total (Surge 3100W), 120Vac (60Hz)
USB-A Output (x2)
USB-C Output (x2)
Specs of 160W Solar Panel
Unfolded Dimensions
61.8 × 26.8 × 1.0 in (158 × 51.4 × 2.4 cm)
Folded Dimensions
16.5 × 26.8 × 1.0 in (42 × 51.4 × 2.4 cm)
Weight
15.4 lb (Solar Panel 11 lb)
12 months
Rated Power
160W (±5W)
Efficiency
21%–22%
Connector Type
Solar Connector
Open Circuit Voltage
21.4V (Vmp 18.2V)
Short Circuit Current
9.6A (Imp 8.8A)
Cell Type
Monocrystalline Silicon
Operating & Storage Temperature
−4°F to 185°F
