Need to quickly charge a Tesla that runs out of electricity? We've got you covered. Our engineer walks through how to charge your Tesla with DELTA.
TUTORIAL 1 Use Charging Gun with Ground Wire
Step 1
Adjust your Charging Current to 15 A
Step 2
Prepare the Charging Gun with Ground Wire, and connect the Charging Gun directly to DELTA
Step 2
Step 3
Charge your TESLA with the Charging Gun with Ground Wire. Make sure the charging indicator is Green
Step 4
Monitor your remaining charging time
Step 4
TUTORIAL 2 Use Neutral Ground Bonding Plug
Step 1
Step 2
Connect DELTA and the charging gun with the Surge Protector using Neutral Ground Bonding Plug. Make sure the status is grounded
Step 2
Step 3
Make sure the Charging Indicator is Green
Step 4
Step 4
A fully charged DELTA allows TESLA to run for 4-5km, could be your best emergency backup.
See the full version of tutorial below:
